1 - 10 of 10 Posts
This spring break, I plan on replacing my rear bumper (smacked up by some thoughtful hit-and-run drivers) and front bumper (sedan to a coupe swap) which means I'll have to get them painted. My question is, will I save much money if I sand them myself or should I just pay the shop and save myself some time and frustration? Any suggestions on how to get the paint off easily? Grit suggestions or special paint removers? Thanks.
Discussion Starter · #2 ·
Oh yeah, I should have mentioned this before just to clear up some confusion. I plan on getting the bumpers from a junkyard, most likely with the previous owner's paint already on it. Any estimates on getting these painted would be nice too. Thanks again.
How much will the paint shop charge for sanding? If it's not much, just let them do it. Also, some shops won't warranty a paint job unless they do all the prep work.
If they don't have a problem with your doing the prep work, try a paint remover like the one POR-15 has www.porproducts.com . Apply in the sun so the heat helps the paint stripper dissolve the paint. Also, try it on a unnoticeable spot to make sure it won't dissolve the plastic. I very much doubt it would, but you can't be too careful.
Damn lol, maybe you should just invest a lil cash and have the whole thing painted heh
BTW how much are you paying for the bumper covers? I can get non-oem from Interstate for my 96 HB for like $30.00 each.
Discussion Starter · #8 ·
I'm going to check out some local junkyards. I'm sure they'll have them. I used to know an actual junkyard search engine that could look up specific cars in your area but I forgot the site. :( I figure I can get them dirt cheap there and save shipping troubles and whatnot.
someone was telling me that(i drive a teg) aftermarket non oem parts cannot have the integra inset into the bumper . does anyone know or have experience with this problem. i would buy non oem if i could but i want it to look real.
Discussion Starter · #10 ·
I don't know about that but would you really miss it? Personnally, I think it would look better without the word "Integra" on the bumper.
1 - 10 of 10 Posts
