If you haven't changed your timing belt get that done ASAP.
Might want to check out the water pump and the tensioner(?) while you're at it.
Change the manual transmission fluid with Honda MTF.
Change spark plugs.
Other than that I would go at your discretion, if you have an excessively noisy valvetrain you might need to get those adjusted.
It might be a good idea to flush your coolant and service your brakes as well, but like I said- at your discretion.
