Louis Wang
The side markers can be wired for single state operation (on with parking lights only or turn signals only) or two-way operation (full-bright with turn signals, half-bright with parking lamps).
Done this way, you'll also need two electrical components per side:
30-ohm, 20 watt resistor
3A rectifying diode
Radio Shack might have these parts; I found mine for under $10 total at an electronics surplus store. The resistors I bought were wire-wound and encased in sand. The diodes were rated up to 25V but anything above 15V should work fine. Depending on how you route the wire, a rubber grommet may be needed. Look around the hood hinge; you should see an approx. 1-inch hole there. From there you can route the wiring to the fender.
I used six splice connectors. Three per side, one for the parking lamp filament, one for the turn signal and one for ground. Remove the headlight assy (three screws) and you will see the wires that need to be tapped. Black is ground, the other two are orange.
With the schematic, it should be self-explanatory from here. A picture is worth a thousand words, heh. But just in case: I used a clothes hanger to run a 4-ft length (12V) and a 5-ft length (ground) to the fender hole through the hood hinge hole. I then soldered them to the copper spades of the side marker socket. I then ran the 12V lead to the components, soldered the connection and used heatshrink to cover up any exposed wire. From there, two 1-ft lengths were routed to the headlight assy and splice-locked to the parking lamp and turn signal leads. The 5-ft ground lead from the side marker was also splice to the assy ground. All lengths are approximate double check before doing anything.
Took me one afternoon total, and that's with running back and forth to Home Depot for needed hardware, heh. Hardest part is probably mounting the components and routing the wires. Cable ties come in real handy.
