I bought my S2000 in February of 2012, shortly after selling my LS1 RX7. I had always wanted an S2K, but the car just lacked the power and gas mileage I was used to with the RX7. The s2000 was all stock with the exception of a 4.77 gear.
While the car still had the stock motor in it and I was still driving the car, I upgraded a few areas. I added a VIS CF Top, BBS Wheels, H&R Coilovers, Corbeau Seats, NRG Steering Wheel and Hub, Invidia Exhaust and a Comptech Intake
At this point the car was extremely loud and obnoxious but still lacked power. So I went to work and started preparing the car for the swap.
I shaved the bay and tucked any wiring out of sight. Added a stock LS1 from a 04 Corvette along with a built T56 from a 02 Camaro. The rear end was taken from an 04 Cobra and the stock Ford axles will be used. Drive Shaft Shop modified a pair of new hubs for me to allow the Ford axles to be used.
I plan to do some autocross and 1/4 mile with the car so I installed a cage.
The LS1 with T56 trans weighs 166 pounds more than the F20c drivetrain, so Ive tried to save weight were possible to keep the car close to stock weight and 50/50.
I removed the stock gas tank and installed a fuel cell mounted in the lower part of the trunk. Im using an Aeromotive A1000 fuel pump, stock Corvette FPR/Filter, and -8 AN line throughout. This setup weighs about the same as stock but is located lower and farther back to help with weight distribution.
The stock cluster had to be ditched since I would not be using the stock steering rack. Autometer Digital Gauges replaced the stock Cluster and a Manual Mustang Rack and Pinion replaced the stock rack.
