1 - 8 of 8 Posts
I came in to work and my lude stoped shifting. :noo
So I put fluid in and notice that it is leaking from the bottom towards the bumper. I was told it could be the slave cylinder. Can anyone confirm that it is right under the radiator hose.(on a H22a)
I just replaced mine the other day. Very easy install. When it goes the pedal will hit the floor (no pressure). You can usually tell by leak around the seal/boot. Theres two bolts to hold it on and 1 nut to attach the line. When its back on you have to bleed it.. Just go by the haynes manual and you cant mess up.
:btu
also, check where your clutch pedal goes thru the firewall, and make sure nothing is leaking tehre.
if it is... your master could be goin out too :fear
1 - 8 of 8 Posts
