Ok..
Here is my problem:
I bought a car from out of state, WA to be exact, and I'm trying to get it smogged here in California but I'm having a problem. The car is passing the emissions test just fine but when the function/computer scan goes through, I fail.
It turns out that my EGR sensor and oxygen sensor are reporting as "not ready" and so that causes me to fail my test. In fact, the only aspect my car is ready in is the heater sensor. (By the way, I recently had a new egr valve and O2 sensor put in from Autozone so it would pass smog) Now, the smog guy said go drive around a while, revv your engine and drive on and off the freeway for a good while and let the system configure and so forth (b/c i guess the system had been reset or something when the parts were put in)... so i did, and it was still not ready. So i take my car, drive some more... and still "not ready" for both sensors....... ok, so by now I take my car and drive up the Altamont pass b/c i figure the mileage and the steep mountain grade would definitely kick my system in... i get back and by now, i've racked up 200+ miles but sure enough the system says again "not ready".. ... so my mechanic now says there's some kind of electrical error somewhere or something. At this point, we're all lost on what could be happening
Another interesting tidbit is that my accord IS having an electrical problem. My drivers control panel (where i control all the windows, mirrors and doors) is completely dead. I had it tested and there is a (+) charge but not a (-) charge, weirdly enough... so the negative charge is getting lost somewhere and that is causing this malfunction. So i also have that to worry about.. but now i'm beginning to think all of this might all be connected to the same problem (the functionality test with the electrical problem, i mean)
So here is the jist again: Egr and o2 sensor will not register and read "not ready", despite 200+ miles driven to get the system to recognize them (a failure or short circuit somewhere?)
and my windows, mirrors and doors will not respond to controls (all fuses and relays are fine)... oh, here's something else that's interesting to note: After the smog or mechanic plugs his computer up to my car, the windows, mirrors and door locks all work for a short time after and until i turn off and turn my car back on. Very weird?
So I think there is a short somewhere or somekind of electrical problem causing my smog issue, which is more important than the windows right now. So if anyone has any ideas, related problems, advice to pass smog, ANYTHING... I would very greatly appreciate it.
Thank you very much and sorry for the long post but i wanted to be thorough about this as possible
Here is my problem:
