so i just took my car to the shop cause i realized i was leaking fluid...
turns out i' racked up a $3600 bill
could anyone help me out with letting me know what's easily fixable myself or with a couple buddies?
my oil pan gasket is leaking- need to replace the filter, then put oil back in.
the front crankshaft seal is leaking- need to replace the seal as well as the camshaft seal
the distributor seal is leaking- i need to replace the o ring
the rack and pinion boot on the right side is torn and leaking- i need to replace the steering gear rack and pinion
the oil filter housing gasket is leaking- i need to replace the gaskets
the boot on the left outer CV axle is dry, rotted, torn, and leaking- i need to replace the left front cv axle
(below are non leaks)
brake fluid flush- is that easy to do?
power steering flush- is that easy?
