what do you use to control the vtec since you dont have the sohc vtec ecu?
this is true but if hes lazy and it seems like it he can use the older ecu to run the motor and it will run better than that but wont choke teh motor. Id recomend changing to odb1 from teh ex or si. its not hard im me i know someone who makes a conversion harnessjdmb16crx said:you need to use the 92-95 civic ex ECU. That ecu was designed to run that motor. The stock ecu for your crx will not have any of the functions that will be needed to run the d16z6. After you switch the ecu's, I would suggest booking a little time at a dyno, so you can tune the car properly, your car will run like it should after that. have fun!
