I warmed up my car today on the way to my sisters house and when i got on the road and started driving the car I noticed that the speedometer doesnt work. Wats going on- would ne one know? Has this happened to ne one.? Is there like some fuse that I can check.....Please help me out Thanks
Sihatch:confused:
Sihatch:confused:
What model is your car... if old model (90) could be speedo cable breaks..if new model could be your speed sensor defective..is the engine light on? if not try to reseat the speed sensor connector and reset the ECU.
Hey my cars a 93- Where would the speed sensor be so I can reset it? Yea the check engine light comes on after a bit- prolly after driving it round for like 5 min. But Ill give it a try. Thanks
Sihatch
Sihatch
Speed sensor located at the clutch beside engine. check this out...
http://www.cybertrails.com/~bestinthewest/autotips/999VSSTestLocation.html
After you reseat it (could be dirty connector) reset your ECU. If still problem.. thats the time you need to replace it.
_______________
CVT 3-Stages Vtec
Discussion Starter · #6 ·
Thanks guys
I finally figured the sucker out..i guess since ive been driving it round this winter the salt from the road got into the plug and then dried up cause build-up of salt between the connectors which in turn cause my speedometer to not work- So what i did was just take the speed sensor off and cleaned it out and now works like a charm. Thanks for the suggestions and tips though.
Sihatch:)
