Hey guys. I have a b16 with bolt on's and Type R Cams. Sometimes, not all the time, when I am idleing the engine revs to almost 2000 RPM then drops to about 500 for just a second, then right back up to 2000 RPM for about 2 more seconds, then it drops again. Someone told me to clean the valve on the back of my intake, tried that, still does it. Any ideas? Thanks
I'm not trying to overtake this thread, but I am having the same problem. I have been searching threads, but I have tried most solutions offered. My B22VTEC has an Integra Type R intake mani and a Holley throttle body. It also has Crane Stage 3 cams. The swap is in a CRX. The idle starts around 2k after ignition, then falls to like 1600. After throttle is applied, idle searching begins. It ranges from 300-2k rpm. Above 4% throttle, it revs normally. The loping continues when clutch is engaged. I have a wideband, and the lean condition when the fuel cuts is the most concerning. Solutions I have tried include checking the IACV for voltage, cleaning and replacing it, and bleeding the coolant system for 15-20 mins. The bleeding helped the problem some, as now at idle, the loping will sometime correct itself after fewer series. A short test drive, however, shows that the problem still exists whenever less than 4% throttle is applied. Please help me trouble shoot this.
