Hello ppl!
1 week ago a problem happened:
I started my car, and when it started, the car kept "trying to start" like "Gr Gr Gr Gr" even though the engine was ON. Then I thought that maybe the key was stuck, so I remove the key and the car went off, and then it started alone!!! with out me pressing the clutch!!! and it kept trying to start! So y opened the hood, disconect the battery so the car went off. I conected the battery and the engine went ON again with out the key! so I drove like that my car like 1 block to the nearest parking lot.
I sent it to Honda Dealer, after a couple of days they told me that it was the starter, so they "fix it". Now they told me that because of the starter got stuck in the flywheel, maybe some of the teeth of the flywheel went bad, so I have to change the flywheel!!! :mad Now every time that I start the engine, it makes a wierd noise only in ignition and since then the clutch pedal is VERY hard!
Could the starter kill the flywheel?
If Yes I was thinking about buying a Fidanza flywheel, is buying a fidanza flywheel is like plug and play? Can I put the flywheel with the oem clutch just like that?
Thanks 4 reading!
:clap
Thanks 4 reading!
:clap
