Thought that was California?
Nope, it's definately NY.
But, bradailey, I understand what you're saying. Maybe you should call your local Honda dealership, or a trusted mechanic, and ask them. Maybe you'll be fine with the aftermarket ECU you have now.
Maybe this will help: Kinda long, but worth reading...
THE UPSTATE AREA - THE NEW NYS VEHICLE INSPECTION PROGRAM (NYVIP)
The Upstate Area has a new program for annual vehicle inspection (NYVIP). The Upstate Area includes the 53 counties located north of the five boroughs of New York City, Nassau County, Suffolk County, Rockland County, and Westchester County.
What is the new NYS vehicle inspection program (NYVIP)?
The NYVIP is a program that will include a new inspection of the emissions control systems on vehicles that have a model year of 1996 and newer. The NYVIP inspection also includes:
the current safety inspection,
the current gas cap check, and
the current visual inspection of the emission control devices.
For the new inspection, the NYS-licensed inspection station uses new equipment to monitor the on-board diagnostic system (OBDII) of your vehicle. The station uses the new equipment, a modem, and a dedicated telephone line to report the inspection results to the DMV.
The inspection station also uses the NYVIP equipment to conduct the inspections for motorcycles, trailers, and vehicles that have a model year of 1995 and older, but the station does not conduct the ODBII inspection for these vehicles.
The NYVIP will help NYS to comply with the Federal Clean Air Act, decrease the emissions from motor vehicles, and reduce air pollution.
Annual safety inspections are required for all vehicles that the law does not exempt. To learn more about safety inspections, read the DMV brochure, "New York State Vehicle Inspection Program for Cars and Light Trucks".
What is "OBDII"?
"OBDII" is the acronym that indicates "on-board diagnostics - version two". The OBDII is a computer system that monitors the correct operation of the engine and the emissions control systems of the vehicle. Vehicles that have a model year of 1996 or newer and that weigh 8,500 lbs. or less have the OBDII. If the OBDII detects a problem that can result in excessive emissions, a malfunction indicator light (MIL) illuminates to inform the driver or automotive technician.
Which vehicles must get the new OBDII test?
The new OBDII test is required for any non-exempt vehicle that:
has a model year of 1996 or newer, and
is more than two model years old, and
displays a weight that is less than 8,501 lbs. on the vehicle registration.
