Very easy question for you all. What's the stock bore on the H22A (4g) throttle body?
D Demonlude · Registered Joined Apr 3, 2002 · 161 Posts Discussion Starter · #1 · Sep 18, 2002 Only show this user Very easy question for you all. What's the stock bore on the H22A (4g) throttle body?
mike_sho · Premium Member Joined Feb 10, 2002 · 13,997 Posts #2 · Sep 18, 2002 Only show this user Ill measure mine , its sitting in the garage right now. Ill post up the info as soon as I find a ruler....
D Demonlude · Registered Joined Apr 3, 2002 · 161 Posts Discussion Starter · #3 · Sep 19, 2002 Only show this user Any luck with the ruler Mike? Somebody must know the stock throttle body bore!!
S Shibby H22A · Registered Joined Feb 19, 2002 · 4,212 Posts #4 · Sep 19, 2002 Only show this user I believe they are 52mm...
D Demonlude · Registered Joined Apr 3, 2002 · 161 Posts Discussion Starter · #5 · Sep 19, 2002 Only show this user 52mm??? I've seen a TB for sale at inlinefour.com, and the bore on this is 70mm!!! I can't believe it would be 18mm wider than stock.
S Shibby H22A · Registered Joined Feb 19, 2002 · 4,212 Posts #6 · Sep 19, 2002 Only show this user Demonlude said: 52mm??? I've seen a TB for sale at inlinefour.com, and the bore on this is 70mm!!! I can't believe it would be 18mm wider than stock. Click to expand... 70 is wayyyyyyyy tooo big for our little stock ports... But yeah that is huge!
