Strobes
583 Views 1 Reply 2 Participants Last post by  Psyk0tic
Well, I just bought some strobes and i have no idea how to install them, They are the Eurolite ones, So if neones done it before just drop a note or two. Thanx
wire it to a switch.....and when you do wire it up just ground the wires to metal. The positive wire try to make them into one wire, which means your going to need to connect them. Here is the order for wiring the strobes with a switch....
Strobes-Positive wires-switch-fuse *corner bulb fuse*.
