Than you need to come to where "most Honda's" are. Hehe!dateg said:o yea, where i live i already kill most hondas on the street. lol, everybody around just has civics with weld on mufflers... very few gsr's, prelude vtecs...
Don't do it... Besides the inherent problems in an LS/Vtec engine, which can be dealt with if built properly, the biggest detraction would be a worse rod/stroke ratio... Increases side loading on your sleeves. B18C1 + SC = Safe High Revs For Mad Power... You do not need the extra torque from an ls/vtec, you will more than make up for the difference with the ability to rev higher safely. Better choice would be to sleeve and bore your B18C1 to 84mm, which is basically a 2L B18C1. It will have a r/s ratio pretty close to stock, although the bore differences will create a slight r/s difference it will still be much better than a typical LS/Vtec.dateg said:i have a 94 gsr, and wanna get an ls block. are ls/vtec good for supercharging? and im thinking of getting a type r head... or is that just a waste of money? and stick with a new b18c1 head?
