Do the coilovers come with dircetions? I want to make sure I install them right. Some people say they have problems with Threaded body scraping against the strut and wearing it down. How would I prevent that from happening? How long does it take for the coilovers/struts to settle in? I heard you have to get an alignment done after they're settled in. Is that true?
This is from a review page: have these paired with Koni Sports, and after having had these on my car for about 2 weeks, I've come to realize that although the ride is good (slightly stiffer than stock), no one is ever going to want to buy a car that makes the noise these coil-overs are making on my car! It is completely unacceptable. Because the top of the Eibach spring rides on a bearing and the bottom is not physically affixed to the adjustable perch, the spring is free to rotate about the front strut assembly. As it does this, the lip of the spring catches and loads pressure into the spring until it breaks loose to spin causing an excessive and embarassing "plong" noise that is audible outside the car. Not only is there a noise, but also the pressure in the spring on one side or another will force the car to pull strongly to the opposite side, making cornerning a difficult, if not scary proposition. If the pressure is released in the middle of the corner with the "plong" sound, I'll find I'm overcorrecting so much that it can be very dangerous, and I'll have to correct evasively. Unless it's absolutely necessary to be able to adjust your ride height frequently,
Is he having that problem because he installed them wrong?
