1 - 20 of 28 Posts
background: 98 sh, with jdm h22 obd1, m2b4 trans, chipped p28 with harness, i installed the oilpump cps/tdc sensor, obd2 dizzy, checked grounds on tstat, valve cover,trans. installed the correct timing/crank sprockets.
update: i put a test light on the icm wire(yellow/green) at the ecu and with the key turned on, there is power. (It is an obd1 ecu with conversion harness)
Discussion Starter #2
c'mon guys. throw out some ideas for me to check out.
i have to be overlooking something
It should spark seeing that you did everything correctly. I assume there should be battery voltage on that wire.
Discussion Starter #4
yup, everything has power. brand new battery and ground cables. I did notice that the rotor was a little burnt so ill replace it tonight. i dont expect that to fix it, but its one more thing to cross off the list. The thing is everything worked fine when i pulled the motor out (except for that that hole in the piston) so i shouldn't have to replaces this stuff. guess i will start with the cheapest parts first.
Discussion Starter #5
I ordered the icm, cap and rotor. I don't think it will help but......
Discussion Starter #8
Added the new dizzy cap, rotor and icm. still no spark:bash
Hmmm... You might need to rotate the distributor. I've done that one myself. If it isn't sitting right, it might be firing early or late.
Discussion Starter #10
its not firing at all though, tested every plug. I tested the dizzy cap, no spark, i tested the icm getting power, i tested the coil, and it tests fine. i tested the yellow/green wire from ecu and it has power.
something is keeping it from spark.
All grounds are connected correctly:bash
if you haven't voltage tested anything then you haven't checked your electrical flow. check for electricity present with a test light or multi meter.
Or try a different ECU if you haven't. From a buddy or someone you may know that has one like yours.
Discussion Starter #15
The car is in Waynesboro PA, 17268.
Willing to pay someone to get the car running.
some detail
just wondering some things,
-with the new ECU did you use the same distributor?
-what kind of ECU
-which engine harness are you using?
-wheres the jumper? from the ECU to engine harness? from the CPK sensors to the engine harness?
Just wondering, hope these aint ingnant questions
Discussion Starter #20
the distrubitor on the car is the 98 stock one
the ecu on the car is a chipped phearable p28 obd1 unit
the engine harness on the car is the stock 98 one
the ecu is connected using an obd2 to obd1 harness
I have the cps sensor plugged into the stock location wire harness plug.
I am beginning to think that this is all because of the ecu and the immobilizer.
1 - 20 of 28 Posts
