I take it having a short shifter will make matters worse.5gencivic said:umm... on saving your syncro's lemme ask you something...
when you shift from first to second, second to third and so forth does going from the lower gear to the higher gear cause the need for the motor to lower it's rpm by it's self before the clutch catches? almost like a power shift you engage first go to redline, at redline you shift and your rpm's only fall to 7500 and by then the gear-shift is in second and you've put the clutch in. if so then this will beat your syncro's as well. you may want to time your shifting correctly. give your motor time to fall to a lower rpm before you engage the clutch.
just a thought... other than that i'd get a new tranny... you're pretty much screwed if your syncro's are gone, they're hella expensive to replace.
yeah... having a short shifter won't nessisarily make it worse, how you shift makes it worse. if you talk to a person from Skip Barber they'll tell you that fast shifts aren't the key, shifting smoothly and accurately is the key. having a short shifter speeds things up but you really need the motor to beable to react quicker to the shift. the thing that would really save you would be a really light fly wheel. thus allowing the motor to drop rpm quicker between shifts, putting you closer to the target rpm.cyberrexer said:I take it having a short shifter will make matters worse.
i have one...i love it!zcivic91 said:ooh!! can we say clutchmasters 8lb flywheel!!
revs drop much faster daniel-son
