i have a 97 civic and my brake lights just quite working my taillights and blinkers work and thats it...has anyone els had this problem or does anyone know how to fix this :bash
check the fuses to all the tail light components. then if they are all good, just replace the bulbs....they are two filament bulbs, one may be blown.
the fuses were fine i changed the brake light switch and all four bulbs and absolutely nothing...i have tail lights and blinkers and reverse lights but no f'n brake lights
.....idk then. maybe you have a short in the wiring.
i had this happen awhile back.. have you ever tapped into any wiring? possibly for a ground or something of the sort. you need to check all connections that you've made and make sure they're still good.
what my problem was is that i hooked up halo headlights, then removed them. i forgot to remove the hot wire and it kept grounding out on the frame, blowing my fuses.
