What size brass/steel fitting is used to tap the block to run an oil feed line to a turbo?
C cmills83 · Registered Joined Mar 12, 2002 · 1,967 Posts Discussion Starter · #1 · Oct 7, 2002 Only show this user What size brass/steel fitting is used to tap the block to run an oil feed line to a turbo?
K KiddEng · Registered Joined Feb 11, 2002 · 1,393 Posts #2 · Oct 7, 2002 Only show this user the tap to the block should be 1/ 8
