1 - 12 of 12 Posts
I have a noise coming from my targa top and im looking to find and fix the noise, I would like to know how to remove the underneath cover or if it is possible to remove it.
I did a google search for reviews on Del Sols and Apparently the 93 models(dont hold me to the exact year) had a couple of bugs, one was noise coming from the removable top.
my guess would be to look at where it connects above your flip down visors, it might be loose up there and then you can prob fit something in there so it doesnt rattle
yeah mine squeaks and creaks when its really dry, i spray it down with silicone frequently and that usually helps out alot
my 93 makes a few squeaks from the rear portion of the top, but nothing horrible. ive always heard most t-tops anyways have some sort of noise to them (dont know if thats relatively true or not)
i got a 93 and it sounds like there is an air leak coming from the driver side of the targa top (like the window is''nt closed tight to it ) but rain doesnt leak through or anything and usually my music is too loud to hear the ugly sounds of my car
Discussion Starter · #7 ·
I have a 94, noise seems to be coming from the piece that secures the top( the one you swing to open or close)
my 94 squeeks louder that hell and i just take it off as much as possible
Discussion Starter · #10 ·
i believe i fixed it, removed the underpiece to uncover a bunch of loose parts hitting eachother, i put cushions between the metal to silence them. seems to work, have not driven a lot since so ill see.
95 sol, not so much souding as if its coming from the targa top more of the passenger side somewhere. It sounds like its glass rubbing up on something. Its like if someone dug there nails into a blackboard, and its all when i go over a harsh bump or some rough pavement. Any ideas No other idea how to explain it really
sometimes its like when a girl yeels at you for leaving the toliet seat up? :lmao heh jk (i think)
Discussion Starter · #12 ·
I heard my window do the same yesterday, not sure what it is, sounds bad though, looking to see if i can find that later on when it stops raining over here.
1 - 12 of 12 Posts
