1 - 13 of 13 Posts
So I got my auto meter a/f gauge. I have to hook up the ground, the accs. 12v. and the signal wire which is supposed to hook up to the signal wire from the o2 sensor. Ok, Which wire in the o2 sensor is the signal wire? Color?
I have a 94 accord ex. Thanks for your help.
Discussion Starter · #6 ·
Ok, I got it. I hooked it up. But, the gauges just switches back and forth, even when I am full throtle. And then, there is like 6 leds lit up at the same time, so if it was in the center it would still cover part of rich and part of lean. Wtf. does anyones elses gague at this way.
thats the its supposed to work
but when you floor it,its supposed to hit into the rich
and when you are cruisin or idling its supposed to bounce back and forth
cause your fuel system is always correction the mixture
and you should read the manuel to understand its function
it all explains it right there
right now you should be running normal since you dont have any force induction or fuel upgrades
Discussion Starter · #8 ·
I DID READ the instructions. And I know the computer is always adjusting the mixture. But what I am wondering is if its always supposed to be so many leds turned on at the same time. Thanks
which wire is it on the same car, but o nthe ecu
i tapped about 3 wires i was told would be it, but none of them worked.
ken
1 - 13 of 13 Posts
