I plan on turning my baby into a high 11's funmobile. I'm going to need cam gears eventually anyways so I figured I could try to run it by you guys and hopefully someone who might know cam gears a little better might be able to help. All of them allow for +/-10 degree adjustment. This is the dilemma:
First of all you have your perfectly acceptable quality AEM cam gears that cost about $80 each. They are made of billet aluminum, have 3 bolts, and virtually no slippage on mildly modified cars. I don't plan on considering my car mildly modified once the turbo is on there, so I don't feel safe using any 3-bolt design for a cam gear, even if it's AEM.
Second we have the 6-bolt Skunk2 cam gear. Made of the same billet aluminum as the AEM, these promise even less slipping for the price of $120 a piece.
Last we have the 4-bolt Spoon Sports or Toda design. These designs use 7075 grade aluminum, whereas the previous designs use 6061 (a cheaper lower-quality grade of aluminum). The 7075 allows for a lighter stronger design. These range at about $300 a pair for either manufacturer.
Now my question is will the 4-bolt design used by Spoon or Toda slip more than the 6-bolt design used by Skunk2? Since the aluminum is stronger in the Spoons/Todas, will that prevent slipping more? Which is the most suitable for a turbo setup that will be in the 11s?
Maybe once this is sorted out this could go down as the first tech archive
