1 - 10 of 10 Posts
Since im soo sick of seeing the same posts on spark plugs i figured id make a sticky as to a decent place to get them if all else fails and some part numbers.
I usually get 7's from Adanced Auto for $1.39 a piece. But thye wont get me colder. So here it is.
www.sparkplugs.com
the part numbers for the following heat ranges
7 Series -
Stock Number for NGK is 2387
Part Number for NGK is BKR7ES-11
8 Series -
Stock Number for NGK is 7173
Part number for NGK is R5672a-8
9 Series -
Stock Number for NGK is 7405
Part number for NGK is R5672a-9
Discussion Starter · #2 ·
heres the NGK database with this also. the ones i listed are at the bottom right, they are for the V-Powers.
The reg ones are right above it.
www.sparkplugs.com
7 Series -
8 Series -
9 Series -
bkr7es-11..how are they different from the ngkbkr7e-11s i been using all these years? do integras stock heat range a 5 or a 6? i always thought it was a 6 but i never see anyone use a 8 series plug before?
the sticker on the side of my JDM b16 calls for a 6 stock.
Discussion Starter · #5 ·
Integras come with 6 range. i think the diff in the ES is the V Power thnig.
I have 8s and 9s for my integra. Every like 100-125HP figure on going up a heatrange
wats the v power thing anyways? is it like a better material or something?
Discussion Starter · #8 ·
all the V power is is a split electrode. i dont think it really makes a difference
You have to know the part number for the heat range you want and then search for it on the site. Thats why i supplied the chart up top. see the 1st part of the post as to where the Honda related ones are. the are at the bottom right corner
1 - 10 of 10 Posts
