it depends on which motor you are putting in. if you are switching from a non vtec motor to a vtec motor you will also need mounts, vtec wiring harness and possibly a knock sensor harness.
Discussion Starter · #4 ·
i m order my d15b engine next week. since most of the engine part cant be found in the states. Will this parts fit the engine :
i found most of this stuff on d-series.com and i wanted to make sure all this stuff was right before i order the parts.
water pump:cx
spark plugs :cx
spark wires:vx/ex/si
belt tensiner:si
timing belt: d16z6 ( do not know what car that out of)
cap and roter: will the ex/si/vx work ?
will any d-series clutch work?
thanks for the much need help!!!!!!
what engine into what car, man. i'm putting a b18b1 into an EG hatch which will bolt in (all minus the stabilizer mount) and plug into the existing wiring harness. just need to use the integra axles
If you are getting a D15B sohc VTEC engine your parts list should look like this
D16Z6 = 92-95 Civc Si hatch,Ex Sedan and 93-95 EX coupe
D15Z1 = 92-95 Civic VX hatch
water pump: D15Z1
spark plugs : D16Z6 (closer to the D15B's oem plugs)
spark wires: D15Z1
belt tensiner: D15Z1
timing belt: D15Z1 ONLY
valve cover gasket: D15Z1
Rear main seal: all honda 4cyl use the same one
Oil pump seal: D15Z1
Oil pan gasket: D15Z1
As for the clutch, im pretty sure all 92-95 D-series clutches are the same.
almost all of the stuff is interchangeable with the D16Z6 except for the Timing belt. The D15B is basically a D15B7 block with the D16Z6 head, and some different rotating assembly parts(beefier & longer rods 137mm, shorter pistons 27mm etc...)
See the pattern yet?
