Can the tps be replaced by cutting off the rivets and tapping the holes and bolting on a new one. My friend would seriously not want to pay 450 bucks for a new throttle body. Any help would be greatly appreciated.
Ok...that sounds simple enough....but do you have to set the resistance like you do on other replacement tps?
Discussion Starter · #5 ·
the reason that i know it is the tps is because we have checked everything else and it all points back to the tps.
find a way to tap into the red wire(the middle one) without diconnecting the plug, turn one the ignition and the voltage should read .5v at close throttle and ~5v at wide open thottle. move the throttle plate slowly and the voltage should increase slowly, make sure there is no sudden jump in voltage.
