1 - 12 of 12 Posts
Swapped in a new engine in my crx last weekend. awesome learning experience, i know so much more now about hondas.
The camera I used liked to turn itself off after so many mins, so there are pauses in the video, but oh well.
Look for random drunks coming in and talking, maybe helpin, using the engine bay as a table for pizza, curts funny face lol, i dunno what else...
Clicky save as
BTW-you need quicktime if this wont play on your comp (www.apple.com/quicktime) its free so dont worry
orijinal_poser said:
good stuff, biotch.... i forget when me & bobby came in the garage, but i remember i was wearing a black shirt
word, the funniest was when bobby came over at 4am drunk, passed out pretty much on the lil stool for a while, then went inside till like 5 somethin when i left...lol
nice vid...its funny u post this cause i just picked up my b16a from the shop and im still piecing together a front end b4 i swap it in...any tips or useful knowledge?
Discussion Starter · #6 ·
I would replace all the lil parts that may go bad soon anyways, its alot easier to deal with em while the motor is outta the car neways. things like plugs, wires, cap, rotor, water pump, timing belt, pcv valve thermostat, and possibly dizzy, alternator, o2 sensors, and tps. the last 4 arent a must but may help later on when you trying to get it to start. I may have forgot some things so check the links at the bottom
ALSO: if you have a DX you have to wire up MPFI so you arent running on 2 injectors...it will run like ass if you dont.
speedjunky04 said:
very nice looks like you have a nice garage. way better then mine :p so If I do I swap I should set aside about a week?
what would you say was the most dificult part of the swap so I can prepare for it?
it took a weekend to get it in and runnin, then an extar day or 2 to get it runnin good. also I took one night before the swap to prep the new engine (clean stuff, replace stuff, valve lash adj.)
hmm the hardest part probably would be the wiring because it can get confusing, but you you follow the pinouts right and wire it up good you will be fine
antoher tip: you have to use your wiring harness and NOT the jdm one, the wires are totally different on the jdm one ( i found that out the hard way lol)
You will need a multimeter to test voltage and resistance to make sure things are wired up right. also a wire stripper and crimper helps, maybe even soldering iron.
lets see if i can get some write-ups i used here
http://crxresource.org/modules.php?name=News&file=article&sid=134&mode=&order=0&thold=0
http://crxresource.org/modules.php?name=News&file=article&sid=72&mode=&order=0&thold=0
http://www.ef-honda.com/ben/Badidle.php
http://www.**********.com/zerothread?id=468260
http://tech.hybridgarage.com/tech/index.html
http://b16a.honda-perf.org/tech.html
http://tech.hybridgarage.com/tech/bseries.html
http://tech.hybridgarage.com/tech/4gtech/index.html
http://tech2.hybridgarage.com/ecu.php?ecutype=pr3_a
I think those are all the good ones, im pretty sure. i may ahve a few more on my laptop, so when im on that ill check and post those up too. Good luck with your swaps!! If you have questions while you doing the actual swap feel free to PM me or hit me up on AIM. :number1
:D :clap
no no no
the best was......
saturday of grand prix weekend!!!
can you say alcohol poisoning?! :number1
whitemike said:
b16's are overpriced and torque less. You could have saved urself a lot of money and just built the d15... could have made more power for less money :rolleyes
nice car man :tu
Agreed, but nevertheless some fuckin hilarious parts in there :giggle
Discussion Starter · #11 ·
nice car man :tu
ya but theres alot more aftermarket support for the b16, and it probably has more potential
thanks for the props guys :D
good shit, u def learn alot about shit when u are doing it. in this new year alone i went from never doing a swap to performing 4 motor swaps, 2 which were unassisted. I completly wired a dx ( b18a1 ) from head light to tail light with a Si body and motor harness and converted dpfi to mpfi.
Post more shit of ur cars progress, the elapes time was a cool idea, i was about to do it for my swapsbut followed up on it
1 - 12 of 12 Posts
