1 - 10 of 10 Posts
So it's time to do the timing belt on my GSR. I have ordered a few parts so far and just want to get an idea what else I need. Stuff I have:
1. Valve cover gaset set with spark plug o-rings.
2. ITR oil pump with gasket
3. OEM water pump with gasket
4. STR cam seal
5. OEM timing belt
I guess I need to stop and get some coolant, and I have all the stuff for the oil change here. Is there anything I'm missing? I guess I could change the other belts, but they look new (no cracking).
if you like, you can get the toda timing belt instead of the oem
hobie237 said:
if ur gonna do it, do it right...
ahaha, i love that phrase,for sho
Discussion Starter · #8 ·
Sounds like a good idea. So here's the next question. How much for the Toda stuff? If it's within reason, I'll probably get one. I now have in my possesion everything bedise the TBelt. I even bought the AEM pulleys and belts.
i used it for my old si, because it last longer, and it has a little more heat resistance material inside. it dosent have to be high powered
1 - 10 of 10 Posts
