cam timing is diferent than ignition timing right?
move the distrubutor forward on the intake cam. if you want to retard like 4 degrees, you will need a timing gun and point it at you crank and see the marks. i'll be posting some pics and stuff on www. h o n d a net.org, so check it out if you want. btw, copy and paste and remove the spaces...integralsWFO said:When you need to retard your ignition timing 4 degrees how do you do it. (running a 75 shot of NOS) do you have to have a new ignition like a MSD DIS 8 which is adjustable
Whoa, a new vtec k-series engine eh?? I know with the obd-2 and up u need an aftermarket retarder, becuase of the ecu resetting timing, I think. So that may be the case of your car too. That might or might not help you, because your timing adjusts per rpm right, or something like that??? Damn these new K motors!!!!!!integralsWFO said:thanks for the help on the first question. I already new that cam timing and ignition timing were two different things I just needed help proving it to someone else. Does anyone know the answer to the timing on the i-vtec
Isn't 18 the max because you will start detonating? I think you can go more, but it's just not safe though right?hondatech2149 said:from the stock setting you can only advance 2.
I don't know how many deg. you can retard.
