Actually swapping out The rotors is pretty easy, I have a 95 Civic EX which i put powerstop cross drilled rotors on. What you do is loosen a couple bolts and the caliper slides up out of your way,
My car has two scres holding the Rotor on, which I just took out and the rotor just comes right off. This would be a good time to paint your calipers while you have the rotor out of the way, just clean the brake dust off best you can before you paint.
You WILL have to get new pads, you don't want to put the old ones back on. and changing the pad is pretty simple to, it's just a clip holding them on, and they only go on one way, so your set.
Make sure you put the right and left rotors on right and left side of the car,Cross drilled and/or slotted rotors are labeled for a reason.
Put everything back together and before you move your car pump the brake a few times to get the pressure back to where it should be And Test drive it Very slowly until you know your brakes are working right.
If everything checks out..you're straight..
Good Luck
