1 - 8 of 8 Posts
What is the right size tire for a 16 inch wheel? The size of the wheel is 7" x 16" the wheels will be going on a car that is lowered 2.25" in the front and 2 in the rear. I need to know something asap.
what car is this going on? it really depends on what came stock on your car. with plus sizing (i assume), you're 1st concern should be to keep the diameter of the 16" the same as what came stock. that will keep your speedo on point.
It will be going on a 93 del sol.
isnbrg9 said:
S or SI? S had 13" rollers and SI had 14"...
edit: actually, it doesn't matter, both should use 205/40-16
i would go 205/45/16, 40 series looks gay on a 16 imo
205/45-16's all the way.
1 - 8 of 8 Posts
