PM for a special installed price! We are in Hayward, CA
Tokico HP Shocks
Tokico HP Shocks Applications and Prices
TOKICO Premium Performance shock absorbers (aka ''Tokico Blues'') have a number of features not found in other shock absorbers. These features allow TOKICO shock absorbers to provide a superior combination of handling, stability, and ride quality. --Piston Rod Guide with Teflon® coated bushing for minimal dynamic friction and good piston-rod life. --Hardened, chrome-plated, and micro-polished piston-rod for long seal life and smooth operation. --Twice drawn over mandrel pressure tube. Concentricity provides good sealing and minimal dynamic friction (drag). -- The heart of Tokico's shock absorber is their unique piston design. Tokico's multi-stage variable aperture sandwich valve system with its precision plates and precise orifice control, allows a flexibility of damping control not found in other shocks. --Tokico shock oil is specially compounded for resistance to breakdown and minimal viscosity change regardless of temperature.
Tokico Illumina Shocks
Tokico Illumina Shocks Applications and Prices
TOKICO Illumina adjustable series offers some of the highest shock absorber technology currently available in the aftermarket.Tokico Illumina gas shock's ease of adjustment and change in vehicle response is second to none. The Tokico Illumina uses a specially calibrated orifice bypass system which allows simultaneous adjustment of both compression and rebound. Each adjustment ''clicks'' so you always know your shock settings. The adjustment range of Tokico Illumina is one of the widest available, with 5 separate positions. Position 1 is the softest, or lowest damping force, while position 5 is the stiffest. Whether you are looking for ride or superb handling,Tokico Illumina is the answer.
Tokico HP Shocks and Tokico Springs Kit
Tokico HP Shock Kit Applications and Prices
TOKICO Advanced Handling Suspension Kits include both TOKICO sport lowering springs and either Tokico Premium Performance or Tokico Illumina shocks and struts. Tokico suspension kits offer a superb combination of improved appearance, great handling, and good ride. You can save money by purchasing the complete Tokico suspension kit versus purchasing the arts separately.
Tokico Illumina Shocks and Tokico Springs Kit
Tokico Illumina Shock Kit Applications and Prices
Tokico D Spec Shock Kit
Tokico D Spec Shock Kit Applications and Prices
The capability of the D-Spec adjustable shock to be such a multi-use product, results from a sophisticated piston and valving design, combined with a unique variable-aperture bypass controlled by an adjustable slide valve. D-Spec adjustments change both rebound and compression damping simultaneously. Between the hard and soft settings, the D-Spec is infinitely adjustable. Each set includes a manual giving pointers on how to adjust the D-Spec as well as various suspension tuning tips.
D-Spec suspension kits will include four D-Spec shocks/struts and four sport lowering springs.
