**HONDA**
heads/parts
-NEW in box Skunk2 Stage 3 Cams for B series Vtec-$500obo
-Ported B16a intake manifold-$75
-Ported and polished 2003 Civic si K20a3 head,no intake manifold,missing 4 valves/springs but otherwise perfect-$200
-'94 Civic cx head..complete and in perfect condition-$40
-'97 Civic ex d16y8 sohc vtec head..complete and in excellent condition-$100
-Stock B16a cam gears-$15
-Stock B16a fuel rail-$15
-Stock B18b cams w/gears-$30
blocks
-2003 RSX type S K20a2 short block..no oil pan,but otherwise complete and in good condition-$200
-'97 Civic ex D16y8 short block..hydrolocked and two bent rods,but good to build on and pretty much complete-$35
-'94 Civic cx d15b8 short block..complete and perfect condition-$100
-'97 Acura TL C32a2 engine..pretty much complete-$300
transmissions/parts
-'90 Civic std manual transmission-$75
-'97 Civic ex rear L bracket-$20
-'97 Civic ex shift linkage w/shifter-$40
-Stock B16a3 flywheel-$30
-Stock D16z6 flywheel-$25
-CRX b16a modified shift linkage-$80
-Stock b16a differential-$30
-'90 Civic/crx rear manual transmission mount bracket-$10
ecu's
-PM6 CRX Si socketed ecu..ready for any chip,comes with stock program chip..$60
-JDM ITR K20a PRC ecu-$300
-'99 Civic si b16a2 P2T manual ecu-$80
suspension
-'90-'93 Integra LS front spindles/hubs-$40
-'90 Civic Dx front spindles w/brakes-$50
-'99 Civic Dx front spindles w/brakes $50
-Stock crx/civic Dx springs and shocks front and rear-$30
engine/tranny mounts
-AVID H22 mounts for 92-95 civic/94-01 Integra-$150obo(no rear mount)
-Hasport rear drag mount for civic/crx b16a swap-$50
misc
-Gsr b18c1 throttle body,excellent condition,no map or tps-$45
-LS b18a throttle body,no tps-$35
-'92-'95 Civic Manual pedal assembly-$50
-'92-'95 Civic master cylinder-$25
-'91 Civic Dx Auto pedal assembly...throttle and brake pedal w/brackets and mounts-$30
-Del sol tail lights-$40
-Del sol removable top-$60
-Del sol doors w/power windows-$200
-Del sol front windshield in perfect condition-$60
**NISSAN**
-'92 240sx power side mirrors-$35
-'92 240sx gauge cluster-$40
-KA24DE fuel rail and injectors-$35
-KA24DE throttle body-$50
-Sentra SE-R rear suspension(hubs,control arms and aftermarket shocks)-$150
-JDM RHD S13 front crossmember,steering rack and brakes-$75
-Pioneer tape deck with harness for '89-'94 240sx-$35
-KA24DE bare head with cam caps and light port work,minor nicks in chambers-$50
-KA24E complete swap from a '89 240sx..rod went through the block,but the head and tranny are still good-$150 obo
