I need specs on GSR head studs, intake manifold, cam covers, and pretty much everything to put it together....know where I can get these specs??....need em by today...thank you!
B18BdxTYPE-R said:i need specs on gsr head studs intake manifold, cam covers, pretty much everything to put it together....know were i can get these specs??....need em by today...thank you!
how about b20 engine?B18B
Valve Cover nuts - 7.2 ftlbs.
Crank bolt - 130 ftlbs.
Cam Shft pulley bolts - 27 ftlbs.
Timing Belt cover - 7.2 ftlbs.
Lower Alternator bolt - 33 ftlbs.
Upper Alternator bolt - 17 ftlbs.
Power Steering pump bolts - 17 ftlbs.
Side engine mounts 38 ftlbs.
AC idler pulley 33 ft lbs.
Timing belt tensioner bolt 40 ftlbs.
CKF sensor mounting bolts - 8 ftlbs
Distributer hold down bolts - 17 ftlbs
B18B cam bearing caps - 7.2 ftlbs
Valve cover studs - 16 ftlbs.
Rocker Arm locknut (B18B) - 18 ftlbs
Cylinder Head Bolts (B18B) 63 ftlbs.
Fuel Filter Banjo Bolt - 25 ftlbs.
Ground wire on from valve cover - 7.2 ftlbs
Cruise control mounting bolts - 17 ftlbs
Side Engine Mount nuts - 38 ftlbs
Exhaust Manifold - 23 ftlbs.
Intake Manifold (B18B) bolts and nuts - 17 ftlbs
B18Cx
Vtec Solonoid - 8.7 ftlbs
Vtec Solonoid Valve - 8.7 ftlbs
Ignition wire cover - 7.2 ftlbs
Valve Adjustmen Locknut - 14 ftlbs
Cam Gear bolt - 41 ftlbs
Timing belt cover bolts - 7.2 ftlbs
Crank pulley - 130 ftlbs
CKF mounting bolts - 8 ftlbs
Timing Belt Tension pulley - 40 ftlbs
Lower Alternator Belt - 33 ftlbs
Upper Alternator Belt - 17 ftlbs
Power Steering Mounting Bolts - 17 ftlbs
Ground Wire to Rad. Support - 7.2 ftlbs.
AC Idler Pulley 33 ftlbs
Side Engine Mount Bolts - 38 ftlbs
Camshaft Holder Bolts - 20 ftlbs
Cylinder Head Bolts - 63 ftlbs
Sealing Bolts - 47 ftlbs
Strutbar Bolts - 17 ftlbs
Cruise Control Motor - 17 ftlbs
Intake Manifold Bolts and Nuts - 18 ftlbs
Exhaust Manifold Bolts and Nuts 23 ftlbs
