word, some people are posting as if we know their entire situation.OhSoFast said:What year/make/model car? What kind of headlight bulb? You need to supply more info. What is your exact problem? Can you not get them out of the box or what?
haha, Don't worry, I think those instructions are the same for 96-00, b/c it's the same way for my car.. The little cylinder plastic container is the power steering fluid.. And yeah, if you don't have an intake, haha, it's a bitch getting to the passenger side light..GhostRider said:well, if it's a 98 EX i can help you out. there's a couple of things in the way. first off, on the passenger side there's a huge ass airbox and if you haven't installed an intake you're up shit creek. you're gonna have to squeeze you little hand in there and take the bulb out and replace it.
on the driver's side, there's a cylinder type plastic container, not sure what's in it but it slides up and out of the way (it's still gonna be connected by a hose but i'll give you enough room) then switch out the bulbs and slide it back it.
hope you have a 98 EX and i didn't type all this shit for nothin'haha
ghost
lol..OhSoFast said:Can you not get them out of the box or what?
Assuming you haven't figured it out yet:adam18750 said:They are very blue, and a little brigter than my stock ones.
BlackDeuceCoupe said:Assuming you haven't figured it out yet:
- Pull the connector
off the back of the bulb
[*]Pry the rubber coveroff the housing
[*]There's a hair-pin style spring clip holding the bulbin place. Squeeze the two tabs that are hanging out and open the clip assembly like a little 'trap door'; it's hinged on one side
[*]Take the old bulbout and put the new onein. They are indexed and only go in one-way
[*]Close the little 'trap door' assembly
[*]Put the rubber coverback on
[*]Plug the connectorback in[/list=1]
As somebody already said, it makes it MUCH easier if you slide the coolant recovery bottle and P/S reservoir out of their brackets, but it isn't totally necessary. I've done it both ways...
Hope this helps!
Hrm... could be taken either way. No harm describing the procedure anyway, right???adam18750 said:Installing them was more work than I thought.
Yup. Maybe someone else will find it useful. Just thought I would point that out.BlackDeuceCoupe said:Hrm... could be taken either way. No harm describing the procedure anyway, right???
ummm, i think that has been established; DUMBASS!!!EVERYONE HE ALREADY INSTALLED EM!!!!
