the Stock ITR headers should clear, tho it would be easier to have the compressor and fans off when you do the header install. I did the ITR header install on my 94 GSR, and with the AC in its a tight squeeze and a lot of pro wrestling to get it in.ok here is my question.. I am doing a poomans itr swap into a 94 vx. Trying to keep a/c for D.D. I have a b16a ac bracket for mount. Which headers will clear a/c and fans?
yeah, they should clear. If your having issues with fan clearance you can go buy an aftermarket slim fan worst case.SO its easier to install with fans and compressor out but it does fit right? are the itr stock headers the only ones that will clear?
ITR = Integra Type R :heheok my last question is what is the difference between itr headers and type r headers? and would they both clear?
