theres soo many different options you could go with... how much are you looking to spend?
here's a pretty good link...
http://coolazz.tripod.com/turbo.html
That site that Dug gave is the one I've been following. I've kind of modeled my custom kit after what that site says and I've spent about 2k so far. Of course I've gotten some really nice things. Including a brand new T3/T04E. The T3/T04E is a great maximum performance/weekend warrior turbo capable of boosting 20psi easily. For the money you're willing to spend you'll have a great set-up.JAYMAN320 said:im looking to spend 35-4500...hows that? Any more and Im back to N/A![]()
well... are you lookig to buy a kit, go with a custom set up, any kind of nice engine management, building the engine any? how much are you planning on boosting? what engine do you have?JAYMAN320 said:Thanks..the link was very informative. Anything else...I know theres some educated people in this forum![]()
greddy might spool faster.. but for the money you spend on there kit, it's not worth itGreddy - MSRP $3,149.00
Includes the following:
Cast Mani
downpipe
internally wastegated turbo
FCU
320 cc inj
piping
Intake air filter assembly
hoses oil lines and misc. hardware
Drag - list price 3,499.00
Includes the follwing:
Drag High flow 4 into 1 cast iron turbo exhaust manifold
Turbonetics T4/T3 TO4E High flow turbocharger assembly
Turbonetics Delta gate Mark II Wastegate (7 PSI Spring)
Drag High Flow front mount intercooler w/
polished cast aluminum end tanks
Greddy Type S Blow off valve
Drag mandrel bent high flow chrome plated pipes
Drag mandrel bent high flow exhaust down pipe
Drag wastegate dump tube assembly
Drag Blue silicone hose and hose clamps
Drag High pressure/High volume inline fuel pump
Drag Boost dependent FMU fuel regulator
Map sensor bypass valves
Stainless steel braided oil feed line w/ fittings
Oil return assembly
All necessary hardware and fittings
All necessary hose and hose clamps
All necessary gaskets
Installation manual
works with automatic or manual transmission.
works with air conditioning.
Mafioso said:what about all the bad things I hear about drag and rev hard.. not street legal.. cracking manifolds.. i can get the greddy kit for 1800 and then get anything else I'll need for 10 bucks over wholesale.. so that's not a big worry.. i just heard alot of bad things about drag and rev hard..
for ur price range this is the best option that i've seen...swap some of the parts in the options and u got a pretty decent setup for ur range.flip1199 said:Well since u wanna spend between 35-4500 i thought might like this option.
Pick the parts u want Turbo Kit
This way u get all the parts u want and won't be stuck with the parts u don't want. Hope this helps.
Once you put a Blow Off valve and an intercooler on that greddy kit, it ain't street legal anymoreMafioso said:what about all the bad things I hear about drag and rev hard.. not street legal.. cracking manifolds.. i can get the greddy kit for 1800 and then get anything else I'll need for 10 bucks over wholesale.. so that's not a big worry.. i just heard alot of bad things about drag and rev hard..
