Here's the thing...on the street, with the stock motor, the variance in compression won't raise the issue of tuning so much as to even make it an...issue. The compression is not that high.
So, those saying that the LS is better because you can mess up while tuning it...is this really your outlook? Do you take your car to tuners who do an "ok" job?
For the most part, on the street...they both won't need too much tuning. The GSR, ideally, will need a little more tuning, maybe a little less timing...but realistically, the problem probably won't even arise. We aren't talking about fully built 670hp drag motors.
Both motors can stand just about the same torture, the LS has the lower CR, and the GSR has the oil squirters...and I see it as an even trade-off if you ask me. So what sets them apart? The GSR has a better flowing head, stronger valvetrain to support a higher redline, better r:s ratio to supprt a higher redline, etc. Power is a combination of torque and RPM.
So, neither compression ratio is good or bad...they pretty much offset each other, and in the end, the GSR will own the LS.
