GreekSpeed said:I would get forged pistons at 9.2:1 CR (your stock compression ratio) for turbo...........cause when u lower the CR u will lose a sginificant amount of power and acceleration when u are not in ur boost range.....cause the turbo doesnt spool up right away......
and for nitrous....... the higher the compression ratio the better performence u get out of nitrous.....but make sure ur shit is forged and stronger than stock if u want to run some serious shots....
well of course i would be just boostin 5 when im just driving around to and from school or wherevers and just knock it up some notches when im racing...but no more than 10psi rite? thats y i need some new internals, for when it comes down to racing. thats all that im worried about...becuase its goin to be a daily driven cardeMad10 said:A stock LS shouldn't boost above 10 psi.
If you are only going to boost 5 psi, I would recommend looking into other options for power. The money spent on a buildup and turbo kit isn't worth it for only 5 psi.
deMad10 said:Well as for cams, a lot of people have better results with the factory camshafts, unless they are cams specific for turbo applications. If you are in there doing piston work I would recommend also buying stronger connecting rods. It is kind of like an insurance policy. The cam gears probably won't get you that much power but they do allow for more tuning. The pulleys will help a little but they haven't been known to produce shocking numbers. In the future you could look to crower's turbo cams. It is not necessary now, but if you want more power without upping your boost it is always an option.
Not a chance. The Drag cars run CR's in the 8's and 9's :1. They're not Superman, they're using the same parts as we do to make our cars fast, but w/o limitations to be used on the street.deMad10 said:There are those drag cars that run 12:1 cr and tons of boost but they have money to burn and rebuild.
