work the suspension first man, TRUST ME its alot more fun then high HP with shit suspensionbigp79 said:thats hott man.....im probably just gonna build up my engine then go for a greddy turbo kit....problem i don't even know where to start on the engine build up
just one step at a time man, LOTS of stuff needs to be preped before you get boosted. thats the last thing Im doingbigp79 said:yeah man i know where to start with suspension i just don't know where to start with building up my engine i just recently really got into cars at the beginning of the year
The clutch is a good idea, but shouldn't you be building the engine before turboing? I've never heard of anyone loweing their car for boost.speedjunky01 said:just one step at a time man, LOTS of stuff needs to be preped before you get boosted. thats the last thing Im doing
here is tha plan I devised
-all refured maintenace first
-lower car
-get everything for alignment
-replace anything work bushings ect.(boost BEATS on parts)
-get some stuff to help plant the power
-new clutch and a good one lol
here is what Ihave done so far
eibach sports,tockiko blues,omni LCA's,megan h-brace,ES motor mounts,ES rear trailing arm bushings,megan toe and camber kit,CTR strut brace,timing belt and water pump, AEM cam gear.
to do:
XTD stage 3 clutch and im ready for some snail man
danijeldanicic is my SN
Im just going to go 10 or so psi, on street gas you cant even push morethen mabby 15bigp79 said:yeah but if you wanted to run a high amount of boost you would have to build it up
well whats the milage and condition on the engine? 9-10 psi is a nice safe number with a good tune, people have pushed it to 15psi on a stocker.bigp79 said:how much boost could i run my y8 on stock internals?
nice, mine has 110k and I plan to boost her.bigp79 said:95k and the engine is good condition everything has been well taken care since i got the car one year ago
about 200~220 to the wheel, at around 10~11 lbs with good fuel management unit, if u gonna go over that built ur internals and get some big brake kits too along with suspensionbigp79 said:how much boost could i run my y8 on stock internals?
Too much go and not enough stop =Vanzgelus said:about 200~220 to the wheel, at around 10~11 lbs with good fuel management unit, if u gonna go over that built ur internals and get some big brake kits too along with suspension
