Greddy - MSRP $1,995.95 and up
http://www.greddy.com/products/images/big_turbo_honda_civic.jpg
Applications:
1992-95 Civic EX
1999-00 Civic Si
1997-99 Prelude Non-SH
1996-99 Integra GSR
1994-95 Integra GSR
1996-99 Integra LS/RS
Includes the following:
Cast Manifold
downpipe
internally wastegated turbo
FCU
320 cc inj
piping
Intake air filter assembly
hoses oil lines and misc. hardware
Drag - list price 3,499.00
http://www.dragturbokits.com/images/kit_v2b_ebay.jpg
Applications:
Acura Integra 1990-1993 All *
Acura Integra 1994-2001 RS/LS/GS
Acura Integra 1994-2001 GSR
Acura Integra 1997-2001 Type R
Honda Accord 1994-1997 4 Cyl **
Honda Prelude 1992-1996 S/SI **
Honda Prelude 1992-1996 ***** **
Honda Prelude 1997-2001 ALL **
Honda Civic/CRX 1988-1991 ALL *
Honda Civic/CRX 1988-1991 W/ B-18 B Motor *
Honda Civic/CRX 1988-1991 W/ B-18 C Motor *
Honda Civic/CRX 1988-1991 W/ B-16 A Motor *
Honda Civic/CRX 1988-1991 W/ B-16 Motor *
Honda Civic 1992-1995 DX
Honda Civic 1992-1995 EX/Si
Honda Civic 1996-2000 DX/LX/CX
Honda Civic 1996-2000 EX
Honda Civic 1996-2000 SI DOHC
Honda Civic 1992-1995 W/ B-18B Motor
Honda Civic 1992-1995 W/ B-18C ***** Motor
Honda Civic 1992-1995 W/ B-16A Motor
Honda Civic 1992-1995 W/ B-16 Motor
Honda Civic 1996-2000 W/ B-18B Motor
Honda Civic 1996-2000 W/ B-18C ***** Motor
Honda Civic 1996-2000 W/ B-16A Motor
Honda Civic 1996-2000 W/ B-16 Motor
Honda Del Sol 1993-1997 SOHC
Honda Del Sol 1994-1997 DOHC B-16A
Honda Del Sol 1993-1997 W/ B-18B Motor
Honda Del Sol 1993-1997 W/ B-18C Motor
Honda CRV 1997-1998 ALL
* Special Order
** Discontinued pending availability of Generation 4
Includes the follwing:
Drag High flow 4 into 1 cast iron turbo exhaust manifold
Turbonetics T4/T3 TO4E High flow turbocharger assembly
Turbonetics Delta gate Mark II Wastegate (7 PSI Spring)
Drag High Flow front mount intercooler w/
polished cast aluminum end tanks
Greddy Type S Blow off valve
Drag mandrel bent high flow chrome plated pipes
Drag mandrel bent high flow exhaust down pipe
Drag wastegate dump tube assembly
Drag Blue silicone hose and hose clamps
Drag High pressure/High volume inline fuel pump
Drag Boost dependent FMU fuel regulator
Map sensor bypass valves
Stainless steel braided oil feed line w/ fittings
Oil return assembly
All necessary hardware and fittings
All necessary hose and hose clamps
All necessary gaskets
Installation manual
works with automatic or manual transmission.
works with air conditioning.
Revhard - MSRP: $2,799.99 and up
http://www.revhard.com/turbokits/kit3.jpg
Applications:
88-91 Civic/CRX (D Series Motors)
88-91 Civic/CRX (B Series Motors)
92-00 Civic (D Series Motors)
92-00 Civic (B Series Motors)
90-93 Integra
94-00 Integra
Stages:
Revhard offers 4 different stages to suit your driving and financial
needs. Stage 1 offers an outstanding quick spool up ideal for street
use, however it limits horsepower compared to Stage 2, which offers
a bigger turbo and intercooler for more horsepower. Rev Hard presents
an all new kit Stage 2C. Designed for beating out the competion and
accomplishing extreme horsepower for the street/race conditions. To
produce the all out race power for the race enthusiast, go with the
Stage 3
Stage: 1
Use: Street
Part #: RHSTG118
MSRP: $2,799.99
Boost Level: 7psi
Injector Size: Stock
Horsepower/Torque: +65 / 215 ft/lbs
Includes:
Rev Hard Cast Iron Manifold
Rev Hard T3 Garrett Turbo
Turbonetics Deltagate (5-7 psi)
Vortec Blow Off Valve
2.25" Aluminzed Mandrel Bent Piping
2.5" Downpipe
Progressive Fuel Regulator
High Volume Fuel Pump
Purosil Hoses and Clamps
Steel braided -3 Oil line
Oil Return Line
High Pressure Fuel Line
High Pressure Silicon Line
Necessary Vacuum Lines
Necessary Vacuum Tee's
Stage: 2
Use: Street/Track
Part #: RH18IT
MSRP: $3,599.99
Boost Level: 9psi
Horsepower/Torque: +120 / 285 ft/lbs
Inlucdes:
Rev Hard T3/T04E Hybrid Turbo
Rev Hard Intercooler
Deltagate (9-12psi)
2.5" Downpipe
Progressive Type Fuel Regulator
Purosil Hoses & Clamps
Steel Braided -3 Oil Line
Oil Return Line
High Pressure Silicon Hose
Neccessary Vacuum Tee's
Neccessary Vacuum Lines
Stage: 2C
Use: Street/Track
Part #: RH18ITC
MSRP: $3,799.99
Boost Level: 9psi
Includes:
Rev Hard Cast Steel Tubular(no AC)
optional Cast Iron Manifold(w/ AC)
Rev Hard 2C Intercooler
Deltagate (9-12psi)
2.5" Aluminum Charge Pipe
2.5" Downpipe
Oil Return Line
Stage: 3
Use: Track
Part No.: RHRACE
MSRP: starting $4,499.99
Boost Level: 25psi
Injector Size: 990cc (Low Impedence)
Horsepower/Torque: 550+ / 395 ft/lbs
Includes:
Rev Hard Equal Lenth Steel
Optional EL Stainless Manifold
Premium Hypo (500+hp)
Racegate (9-12psi)
Godzilla Blow Off Valve
2.5" Downpipe
Oil Return Line
Fmax - $3799.00
http://www.f-max.com/civic1.jpg
Available Applications:
92-95 Honda Civic D16
96-00 Honda Civic D16
92-00 Honda Civic B16A, B17, B18B
92-00 Honda Civic B18C1
92-93 Acura Integra B16,B17,B18
94-00 Acura Integra B18C1 GSR
94-00 Acura Integra B18B LS
92-00 Honda Prelude H23A
92-00 Honda Prelude H22A
97-00 Honda Prelude H22A4
94-97 Honda Accord , 2.3L
98-00 Honda Accord 2.2L VTEC
88-91 CRX/CIVIC
Icludes the following:
FMAX High-Carbon Cast-Steel manifold
Closed-Loop Mandrel Bent Downpipe
Intercooler Piping
Intake Pipe
T3/T4 Hybrid Turbocharger
Deltagate External Wastegate
Intercooler
A K&N filtercharger
HKS Racing Bypass Valve
Additional Injectors
ERL MF2 Addictional Injector Controller
MSD-BOOST TIMING MASTER
rideal Head Gasket
Full Race - $3,899.00
http://www.full-race.com/products/images/turbo_kit/003.jpg
Applications:
none listed
Includes:
Full Race Equal Length Manifold
Full Race "Back Door" Intercooler
Full Race Downpipe
Garrett T3/60-1 Turbo or Garrett T4/T04E 60 Trim Turbo
Tial 40mm Wategate
Tial 50mm Blow Off Valve
Aluminium Intercooler Piping
Full Race Oil Line Kit
Silicon Couplers / Hose Clamps
MaxRev - $2,899.00
http://www.maxrev.com/photos/1036605510_1.jpg
Applications:
none specific
Includes:
Large front mount intercooler
Do it yourself piping kit
Maxrev billet Blowoff valve and mnt
stainless oil line kit
stainless steel B series manifold
2.5 inch stainless downpipe
Tial wastegate
Garrett t3 to4E 57trim stage 3 turbo good for 400+hp
Hardware-clamps,couplings,small hose and T fittings
i searched for a site that compared turbo kits non-biased and came up with no luck, so i figure a post like this would be of intrest to those looking into buying a kit.
Applications:
1992-95 Civic EX
1999-00 Civic Si
1996-99 Integra GSR
1994-95 Integra GSR
Cast Manifold
downpipe
FCU
320 cc inj
piping
Applications:
* Special Order
Oil return assembly
Installation manual
Applications:
90-93 Integra
94-00 Integra
Stages:
Stage 3
Stage: 1
Use: Street
Part #: RHSTG118
MSRP: $2,799.99
Boost Level: 7psi
Includes:
2.5" Downpipe
Oil Return Line
Stage: 2
Use: Street/Track
Part #: RH18IT
MSRP: $3,599.99
Boost Level: 9psi
Inlucdes:
Deltagate (9-12psi)
2.5" Downpipe
Oil Return Line
Stage: 2C
Use: Street/Track
Part #: RH18ITC
MSRP: $3,799.99
Boost Level: 9psi
Includes:
Deltagate (9-12psi)
2.5" Downpipe
Oil Return Line
Stage: 3
Use: Track
Part No.: RHRACE
Boost Level: 25psi
Includes:
Racegate (9-12psi)
2.5" Downpipe
Oil Return Line
Fmax - $3799.00
88-91 CRX/CIVIC
Intercooler Piping
Intake Pipe
Intercooler
A K&N filtercharger
rideal Head Gasket
Applications:
none listed
Includes:
Full Race Downpipe
Tial 40mm Wategate
MaxRev - $2,899.00
Applications:
none specific
Includes:
Tial wastegate
