sak said:
... the B18C's external dimentions look way bigger than the F22 engine...
Look man, I'm not reffering to specs on what one has and what the other doesn't. I'm reffering to external dimensions here? Are we talking the same thing here?
I'm merely comparing the external size of the two, nothing more. And I didn't say it was bigger, I just sadi it looks bigger because who even knows the exact dimensions of the two. Have you measured it yourself?
If you compare the B16 to the B18C you would automatically say that the B16 is smaller because its a 1.6L compared to the B18C's 1.8L. But if you just look at the two it sitting there, engine next to engine, and not look at the block number would you be able to tell which engine is the B16 and which is the B18C? And don't look at the valve covers either since the
DOHC VTEC label on it gives away a clue.
Honestly, you can't tell the two engine apart unless you look at the block numbers. The exterior dimentions are pretty close. So when I said that the B18C looked way bigger than the F22, I was reffering to exterior dimensions. Hope you understand what I was trying say.
