1 - 20 of 23 Posts
Sorry i ask so many question but i wanted to know whether or not you can buy and install a turbo on a stock del sol without anything going horribly wrong! PLEASE HELP !!
complete!!! wheres the fuel management, plus the quality on the turbo is prob not the best :bash
my turbo is internal wastegate so I am not too sure about the external ones, but i think it is missing the oil feed and drain lines, fuel management either fmu or something else, injectors if running chipped ecu, not too sure about fitting it in w/ ur AC and power steering either..
Discussion Starter · #8 ·
Damn. every time i ask where they bought something it was either local or a friend. thanks. well then can you maybe point me in the right direction to a cheap, complete, turbo kit :confused
I dont think cheap and turbo belong in the same sentence. :eek
depends on your budget, and your knowledge. small budget+knowledge=pwnz0r. big budget+knowledge=crazy.
www.homemadeturbo.com
Discussion Starter · #11 ·
I know that i was just sayin not like real ridiculously expensive
and my budget is around 1500-2350 i don't know much about turbo but want to learn. any help would be appreicated. Thanks :number1
Most of the time when I see cheap someone wants to build one for a few hundred. Homemadeturbo.com is your best bet also check out turbod16.com (more info for newbies) hope this helps.
1 - 20 of 23 Posts
