I have a HKS turbo timer that I want to install but I didnt get the jumper harness with it, It only came with the pig tails/conectors from the timer side ( got it for free ) how would I go about hooking this up? I never installed one before so any help would be appreciated.
Thanks
Turbo timer wiring
Here's a photo of how your timer's wiring should look. The red wire goes to the 12 volt constant. The green wire goes to the accessories that keep your car running. The blue wire is a secondary accessory wire that lets you run another accessory while the timer's counting down. Pretty easy. There should be a black wire, that's always the ground. If there's a brown or grey wire, that's for your e-brake switch. If you look down at the base of your e-brake, where it's bolted to the car, there should be a small screw pushing a switch when the e-brake is released. The wire coming off of this switch is what you need to hook your brown or grey wire to. Hope this helps!
