Search is a great tool,
other then that.....I'd get rid of all that stuff and start over.
Never heard of a turbo chip before, what is it?
If you run low impedence injectors (dsm's) in an engine that uses high impedence injectors then you'll need a resistor pack....doesn't have to be from a dsm...
Ditch that rising rate fuel pressure reg and go with something a little better for fuel management.....
As far as injector size, that depends on what you use for fuel management. If your using the fmu (rising rate fpr) then you'll want to find out what ratio it is. If it's 12:1 then use stock injectors, if it's 6:1 or 8:1 then 310cc injectors will work....anything above that then you'll need an afc or better tuning device to control the injectors...
