My 93 Del Sol the turn signals and flasher on the right side quit working. When you turn the left signals on they normally with the indicator light on the dash showing that. But when you turn the right signals on, no indicator light shows up and you hear a quick clicking from the relay and the turn signals and the flashers on the right side are not working. I have checked the bulbs they are good. I did replaced the turn signal switch thinking that was the problem and that was not the problem. Any suggestions on what I can try. I know there is a turn signal relay but would only one side of that go bad?any help would be appreciated.
