Tried this out this weekend. I had used Meguier's headlight restoration kit which sucked.
So far, the result was much better. Plus it cost less than half of what Meguier's costs, i.e. less than $10.
You get this lubrication spray, polishing liquid, sealing liquid, a glove and three pads. Pad 1 is roughest, pad 2 is finer, pad 3 has two surfaces (one is finer than pad 2 and the last one is the finest).
You get more than enough product so you don't have to worry about running out. There is no headlight lens out there where you would run out. You could do two sets of headlights.
Discussion Starter #5
It's May 20th, that's like over 10 months. The lenses are hazy again. So, this one lasted longer than the Meguier's system. Not too bad.
I'm thinking of trying the 3M headlight restoration kit next.
