My moms 94 civic ex abs sedan automatic has a couple problems I just recently noticed.
First, it seems to stay in second gear longer than any other gear. This is especially noticeable when in residential areas where the speed is always under 25. Example: it won't shift into third; it'll stay in second at around 1300rpm @ 23-24mph....unless I press the accelerator more. Is the second gear really this long, or is something wrong with the autotranny? Maybe its not supposed to shift into third at that speed or rpm? Oh, and it does this both when cold and fully warmed up. Tranny fluid is good (pink and correct level).
Second, when at a stop light, and brake pedal applied, the idle is low. I know the idle is supposed to be somewhere around +/- 750 rpm w/o a/c on, but at the stop light, it hovers around 600. It never dips below 550 however. What up with this? It doesn't idle rough or anything at that rpm, and i checked all the vacumm hoses i could find...could it be the pcv valve, egr, iac, fast idle, throttle body, barake booster, what?
The car has 70k mile on it. Had tune up at 60k (plugs, cap rotor, fuel fiter etc).
Any help would be much appreciated.
