Holy old thread Batman!
If you don't want to spend a few thousand bucks on TOP of your turbo build to make a crazy high compression turbo build, then no, go back to stock LS pistons.
The low compression that the LS piston set up gives makes it easy to boost reliably when tuned correctly. It takes a LOT of professional work and usually drag race only applications to mix high compression and boost using water-meth injection.
Your rods are also probably milled 1mm each side to make the Type R pistons fit on stock LS rods, so you may need to grab stock LS rods as well.
So if you want to keep it basic, and enjoy a 300whp setup (if your block is healthy), you'll need to swap back to stock or aftermarket pistons that yield a compression of 9.2:1 (stock) or lower.
