as a matter of fact arent the fuel pumps the same...? i thought only injectors and thelarger fuel mapping was the difference..stock fuel pump should be sufficient. Are there part differences between a GSR pump and a D16 pump? My guess is probably not.
No. only the ek 99-00 civic si's pump better fuel pump can handle UP to 400, anything more will overwork the ump and starve teh engineI don't think you should replace your current fuel pump. unless its broken. Stock fuel pump should hold even if you reach 400hp+.
______________
honda parts
